R
R.Robertson
I just passed 17th edition as most jobs I'm looking at require it, took me 5 weeks to do all courses, thing is the misses dad found out and asked me to have a butchers at his consumer unit because it was stinking, I had a look and the consumer unit and it was fine as I dutifully done all the testing, I then followed supply cable back and there is a supply isolator switch rated at 43A for the enclosure and 30A rewireable fuse and it's basically burnt through the Bakelite and the insulation of the cable, what may have caused it? The fuse hadn't blown and the MBC hadn't gone either, also shouldn't RCD protection switch to OFF when power goes off?
If this is in wrong place, sorry and could you redirect me pleeeease?
