Not sure if this is right place to post but, HEEEEEELP!!! | Page 2 | on ElectriciansForums
Discuss Not sure if this is right place to post but, HEEEEEELP!!! in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
On the shaded bar under each post you'll see the thanks text. Click on the Thanks and it will post up under the post...
if less than a year old there is legal implications on the installer , even if he has did a runner, one possibility may be the tightness of connections, may be a big job but personally take all switches and sockets off make sure tight etc, as if your doing the inspection and give pass certificate for work done you could leave yourself liable for things
imagejpeg
Connection was loose on cu side of fuse, all sorted and ship shape now
imagejpeg
congrats.... believe me this forum is top. for me and you (new to the trade) they really help out. a college course teaches you the rules and basics. but when you start to do the work....and find other peoples work some bad then thats when you start to learn the trade (like i found a 9KW shower fed from a spur on the 32A ring). and the guys on here with there experience and knowledge really help out.
on here they are really helpful top guys!
WELL DONE WITH YOUR PROBLEM.
Reply to Not sure if this is right place to post but, HEEEEEELP!!! in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
It's not the same scenario, though. Tails more than 3mtrs can be overcome by using a fused switch and rcd board, whether the earthing system is...
It won't be notifiable though as its not a new circuit, if you change the the tails from 16mm to 25mm is that notifiable? No, if you add an...
