nothing like being thrown a curve ball | Page 2 | on ElectriciansForums
Discuss nothing like being thrown a curve ball in the UK Electrical Forum area at ElectriciansForums.net
fife
I was asked to change a light fitting in a neighbours house easy job help out a neighbour I thought. I had my 2nd oldest son with me so thought it would be good to show him how to work safely ie how to use a voltage indicator and work safe.
normal procedure
prove indicator using proving unit
check voltage at light fitting
demonstrate fitting dead (lock mcb off)
prove indicator with proving unit
get young lad to disconnect light and he said I've just had a shock from wiring (single twin and earth at light ) I thought I just checked and its dead so I checked it again and no voltage so I decided to do it. I got a cracker of a shock made me look like a total plank in front of young lad so I checked again, no voltage between L+N but 240 between L+E.
turns out when there smart meter fitted the installer made a small mistake (don't know how to find sarcastic emoji)
turns out the MCB switched the neutral as L+N reversed
anyone else had something like this
and DNO contacted to rectify issue
Everyone's perfect on here when it isn't them who made the error. :)
In fairness I'm pretty certain that many would just switch the light on, see which MCB made it go off then just crack on, in fact a one cable light fitting job would be 'safely isolated' by many just by turning the switch off. :rolleyes:
If the meter fitter had checked their Martindale pre and post job, it would have alerted them to the mistake they made. Not following what is a very basic and simple procedure is inexcusable really.
Also, visually checking and tracing cables after the job (which should have been tagged and identified before removal) takes 2 seconds ... and there are usually only four to look at!!
I had a DNO engineer out a couple of moths ago to remove a meter and install isolator. He reversed the tails but checked polarity on completion and corrected mistake.
An interesting time concept... was it the a month was too short and moths generally live for 5 weeks?? :tearsofjoy:
Reply to nothing like being thrown a curve ball in the UK Electrical Forum area at ElectriciansForums.net
There could also be a completely unsuitable junction box embedded within the wall and tiled over or just cables in choc blocks in old accessory...
When you did the further testing and got the 0.06 reading were the CPC's back in the consumer unit? Really when testing you should leave the...
