I set up my company this year and want to make sure im doing this right do i just need to notify a job when i have added a new circuit or bonding or worked in a special location?
Discuss Notifications??? in the Australia area at ElectriciansForums.net
replacement of fittings without modifying a circuit does not require certification, however, as above, it a good idea to test and issue a MWC to cover your back. customer cannot say then that when another part of the installation, which you have not touched, goes wrong, it's your fault.thought as much cheers also the thing i was wondering was do you have to issue a minor works for the likes of changing a socket front or swapping a light fitting?
but what do you do when the customer does not want certification. no i dont want one thank you i dont want the council notified at all.
Reply to Notifications??? in the Australia area at ElectriciansForums.net
