Notify change of modules | on ElectriciansForums
Discuss Notify change of modules in the Green Lounge (Access Only) area at ElectriciansForums.net
T
TJLinks
is there a requirement to notify the DNO, FiT provider etc when changing modules? The inverter is staying just the modules being changed from silver frame to black frame. System has been in operation for approx five years.
I do not think the DNO will be worried, but from memory the FIT supplier will, because changing the panels potentially changes the TIC as the FIT suppliers define it.
The answer must be:
- read the letter giving authority to generate in parallel. (Here, WPD issue one.)
- read the FIT contract
Reply to Notify change of modules in the Green Lounge (Access Only) area at ElectriciansForums.net
    • Friendly
It applies to commercial if it shares the same supply as a dwelling.
I have an "old school" electricity monitor similar to this one...
