Nu-Heat Ground sorce heat pump boilers? | on ElectriciansForums
Discuss Nu-Heat Ground sorce heat pump boilers? in the Central Heating Systems area at ElectriciansForums.net
R
robie
Hi, does anyone have any experiance with ground sorse heat pump boilers by 'nu-heat'. Ive had a nightmare getting information just to first fix the cables between the controlls, tanks sensors and boiler. If Im totally honest, a heating system even with underfloor heating zones, or hotel systems with multiple zones and controlls are ok to do. But this systems is so confusing, theres 3 floors of underfloor heating, a back up boiler (which is two immersion heaters controlled via relays) which is controlled via a programmer from the ground sorse heat pump boiler which on its own is pulling 29amp's. I think if the drawings were a little easyer to read i wouldn't panic so much but i am!
Has anyone else worked on them?
Reply to Nu-Heat Ground sorce heat pump boilers? in the Central Heating Systems area at ElectriciansForums.net
Thanks I understand it now just getting to grips now with the different types and different ways of wiring them
If you can see a piece of plastic entering from the ground then (as cliff said), it does not need main bonding. I think (not sure) this is reg...
