united kingdom...yorkshire
I rent a semi detached house out which was built 1970's
With the tenancy just changed i thought i would change the original fuse box to a modern one with rcd's and mcb's before he went in.
Even though there is no legal obligation to do so and the wiring is still good I did it.
I had loads of tripping probs when first installed as the maze of wiring which has evolved around the house probably had neutrals crossed (split C/U with 2 x rcd;s)
Finally got this all sorted and had the house EICR checked sucessfully.
The tenant has now been in a month and he informed me 2 days ago his sockets were tripping the rcd for that particular bank of mcb's.
I temporarily replaced the affected rcd with a double pole MCB and all was fine.
So with everything umplugged and the rcd back in, i attempted to find the offfending socket or piece of wiring what was tripping the rcd.
After 7 hours or disconnecting, testing, carpets up, floorboards up, decor damage around sockets I was getting nowhere.
AS the wiring to the house has evolved over time it was impossible to know which cable ran where so to get him back online and get the sockets, floorboards and carpets back before it got dark, I put in the 60A double pole mcb back in in place of the rcd.which was supplying that particular side of the C/U.
The rcd is 63A / 30mA.
Can I leave it like this with a 60A MCB in place of the rcd which supplied the sockets?
If I hadnt changed the fusebox for a newer C/U this problem would never have arose.
I understand rcd protection regulation applies to rewires and new installations.
This house has not been rewired nor is it a new installation so as the regulation is not retrospective can i leave the MCB in in place of the rcd.
At least it is better than it was as there are now mcb's rather than fuses and individual circuits now have their own MCB.
Another question, is it also an option to give rcd protection by installing say a 100mA rcd which is not as sensitive....this may hold.
To rive up every carpet and floorbaord in the house and move every bed and piece of furniture trying to physically follow the cabling is a mountain of work and disruption when fitting an mcb will stop this nuisence tripping.....
I wish I had left the old fusebox in.
Advice would be gratefully received.
Thank You
John
Thank You
John
