Numeric core identification. | on ElectriciansForums
Discuss Numeric core identification. in the Australia area at ElectriciansForums.net
Belfast/London
Guys I would like some opinions on the use of numeric cable core identification for LV circuits. See 514.5.
Eg. If using a 5 core YY flex with all cores coloured black and marked in white with 1 - 4 plus a green/yellow cpc. Can these be connected into a DB without any addition sleeving ie. Core 1 to L1, core 2 to L2, core 3 to L3 and core 4 to neutral.
Strictly according to the regs, then no, not required (see 514.3.1 (i) which explicitly says and/OR). The use of or implies that using either colour or one of the number/labelling schemes is the only requirement. Not sure it's good practice though.
Reply to Numeric core identification. in the Australia area at ElectriciansForums.net
Absence of correct labelling is a C3, reversed polarity is a C1 (BPG-4). You choose.
