Guest viewing is limited
View the thread, titled "Numpty cooker cable / new hob & double oven Q" which is posted in Australia on Electricians Forums.
T
torpenhow
Hi Folks,
Advice gratefully appreciated! Mrs T is having new induction hob (7KW) and a double oven (4.1) installed.
The existing electric hob and oven is supplied by a 10mm cable.
Is the 10mm existing cable sufficient for the new oven and hob? Assuming it is, how do I supply the two items from the one cable? At the moment the 10mm cable is terminated at a wall mounted cooker switch with a socket with a 45A mcb at the consumer unit.
Thanks again.................
For me Simon it would be areas that store flammable material, for instance a Silo or Grain Store.
Also Petrol Stations, any areas that would have chemical such as a battery storage room for a UPS system, things like that.
These areas though have special and often other BS to work to. But I'm sure we will get discussions about a kitchen being more susceptible to fire than a bedroom, which of course it is, and could therefore be classed as an area that presents a fire risk
And than it leaves situations like the OP's above which is very common as a big no no if interpreted like that.
Sent from my GT-I9100 using Tapatalk
Yes James, are you going to refer to the new part about branch circuits and sockets added to it in the amendment, I noticed that as well.
No Malcolm, you flatter me. I was only going by the BRB. I was just trying to see if I could match up an unquoted (by number) reg with the actual one it pertained to.
Cheers
Reply to the thread, titled "Numpty cooker cable / new hob & double oven Q" which is posted in Australia on Electricians Forums.
