NVQ Questions for Knowledge Assessment!
DurhamSparky
Guys, Need to complete this bit, its badly worded and badly put together rubbish that unfortunately i need to complete, even the tutor said its badly written
Q1 How would you interpret diagrams and drawings to find site services and the planned location of the wiring systems, wiring enclosures and equipment?
Q2 How do you determine the suitability of fixing methods to building fabric in the environment of the installation? (305)
Q3 How do you handle wiring systems, wiring enclosures and equipment in the correct manner? (305)
Q4 What are the most effective methods of fabricating wiring enclosures? (306)
Q5 What are the procedures for carrying out an assessment of safe systems of work including permits to work? (307)
Q6 What are the latest, relevant industry standards applicable to diagnosing and correcting faults in electrical systems and equipment? (302)
if you fancy a crack at them i would be very much pleased!! they probably easy to give answer to but my head dont work at min..
Hi there,
you say you have the complete set of model answers for the EAL NVQ 3 knowledge questions. I would really appreciate a copy if at all possible and if i can work out how to re word them ill let you know ...
Upvote 0
If i get time at work tomorrow i will have a look at my L3 answers. I wont pass them on parrot fashion, but i will try and point you in the right direction. These questions are designed to make you think a bit, and put your answers down in you own words.
Cheers............Howard
Upvote 0
Hey Ezzzeikiel, i'd really appreciate some help too. I'm doing my underpinning knowledge questions for my nvq3.
Upvote 0
10. A motor is reconnected into a circuit and then switched but runs the wrong way, how will you correct this malfunction and how could it have been prevented from happening.
Upvote 0
I'll appologise for being an absolute arsehole now.
Hi there,
So, you basically mean that you can't be arsed to attempt it yourself, and you'll use someone elses answers? Not being funny, but most of us have done an NVQ level 3 and we all got by. Why don't you post the question you're stuck with on here - then have a go yourself - and then we can correct you. Don't expect to have your arse wiped for you.
What question(s) are you stuck on?
This is a faily straight forward question buddy, you will know this, and you'll kick yourself if someone has to tell you :) - have a little attempt first then we can point you in the right direction - don't try an over complicate things :)
Upvote 0
Electrical Courses
