Obvious question more than likely. | on ElectriciansForums
Discuss Obvious question more than likely. in the UK Electrical Forum area at ElectriciansForums.net
J
jwc
Second question of mine on here and it's one I've never got round to getting an answer for.
Mains comes into a building through a 60A main fuse for instance.
Why then are main switches rated at 100A or 80A?
Does this mean any load above 60A would blow the main fuse before it blew the main breaker?
Don't be harsh people. I'm fully aware the answer's probably an obvious one.
Hi. The answer is in the terminology. When you write "Why then are main fuses rated at 100A or 80A?" you probably mean "Why then are main switches/RCDs rated at 100A or 80A?"
The switch rating is not related to your supply rating (but needs to be same or more)
Just received an inbox stating that the main switch doesn't trip on overload? :/
Really? Thought the main switch was essentially an MCB to carry the load of the other MCB's if that makes sense?
How? haha.
I just wanna know what's the point in having a main switch with a higher rating than the main fuse which supplies it?
Surely you want your main switch to disconnect before the main fuse blows?
If your main fuse is 60A, main switch is 100A, and your house is pulling 80A, what use is the main switch?
totally wrong. the switch is a 2 pole switch, nothing more. each circuit is protected by it's own MCB. the installation as a whole is protected by the DNO fuse. think of the switch as your car. it will do 110 mph, but you run it at no more than 70mph.
JWC - Its hard to respond to a question sometimes without been harsh but im scared to the fact this question comes up numerous times from 'Qualified' Electricians now im starting to think you in yourself are not to blame here but either your tutor or the course itself .... may i ask what kind of course you have taken... now you realise that the main switch is just a mechanical switch and nothing more its brings to question are other areas of your learning lacking in basics ..... this could be dangerous in design in some situations if you thought the main switch on a standard dist-board afforded overload protection.
Hope you dont take as a dig at you...
To note hear you can get main switches although usually in larger commercial and industrial boards that do afford overload protection 'MCCB's and or a combination of earth leakage protection.... maybe this is where you may have confused yourself, but your bog standard 17th edition board DP switch is exactly that - a switch without the perks.
Thanks for the explanation, Darkwood. I've completed a full apprenticeship, AM2 and NVQ Level 3. Everything's much clearer now knowing that the main switch is exactly that... A switch.
Reply to Obvious question more than likely. in the UK Electrical Forum area at ElectriciansForums.net
I can imagine it just disappearing (loudly) under short circuit conditions, then the resulting blast/plasma etc. casing the busbars to flash over...
I can't help wondering about earthing arrangements and how important aesthetics really are when attempting to make the best of a less than ideal...
nicebutdim
N
