Occupancy sensor.. No neutral required? | on ElectriciansForums
Discuss Occupancy sensor.. No neutral required? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
T
TPES
Does anyone know where i can get one from? Looked on danlers website but can't see if they do a neutral free option
All the one's I've ever fitted have needed a Neutral.
I would assume that a neutral is needed for the PIR control circuit and relay / contactor
I have used no neutral presence detectors a few times. Cant be sure of the manufacture as im not in work but i think they where from a company called CP Electronics.
I can confirm on Friday and give you the part No of the one we use, have fitted many and had no issues.
Sounds good. I'd appreciate that. Thanks
You can get these in senate. It works without a neutral as you connect a capacitor across line and neutral in the light fitting this then trickle charges the internal battery in the switch.
Reply to Occupancy sensor.. No neutral required? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hope everyone has had a great Christmas and here’s hoping we all have a better new year coming our way ! Remember our riches aren’t measured by...
    • Friendly
Thanks so much for sharing this with us! I’ll definitely take a look, it seems like there are a lot of useful and interesting products. The idea...
Hi. I have a wired Optima alarm. Due to wiring access issues, I need to add a wireless door sensor. Sometime back, I recall seeing a product that...
Thank you, both. Seems like common sense may have prevailed, and the fellow is indeed going for one of the modern mirrors you mentioned...
