View the thread, titled "Odd E.V. home charger question" which is posted in UK Electrical Forum on Electricians Forums.
I will describe my problem in as much detail so you guys might be able to answer my question. I am never home, my Electric bill is $ 28 to $30 a month, has been that way for years.
I recently bought an E.V. so I had an E.V. Charger (Emporia is the brand) installed, hardwired by an Electrician. BTW, charger is set to 40 amps and I don't have breaker box I have fuse box, 50 amp fuses
The 1st month I used my charger 4 times from almost empty to a full charge. The bill was $128 and change, which tells me it cost about $25 per charge when it should cost about $9. My power company rates are
13.2 cents killowatt and Emporia charger will use some power if it is powered on with no use. Emporia told me a few dollars per year. Next I did not use my charger for a month just keeping charger power on. The bill was $ 48. just with charger power on. Finally
I removed fuse cutting all power off charger and the bill was the normal $ 30 and change. My only conclusion is that Charger is costing me about $18 a month just keeping it powered on, but not using it to charge car. Am I crazy? Can this be fixed?
My power company rates are 13.2 cents killowatt
Are you sure this is your rate?
Your profile suggests you are in Connecticut.
From what I read that the average domestic rate in Connecticut is around 23.5 cents per kWh.
The reason I ask is that we are working out your usage from the money you pay, but if that is not quite right, your usage may actually be a lot less. It's just that electricity prices in Connecticut have become pretty high!
Do you have other charges to pay as well? Here in the UK we have a 'standing charge' of so much per day, irrespective of how much electricity we use, so it's more tricky to work out actual consumption purely from monthly payments!
Yes, I called them. I have been going over this in my head and can't figure it out but Monday I will call my Electrician, maybe they can measure the power consumption, we will see.
This is the reply from the electrician, who installed charger.
"The wiring is all new and correctly sized (#6AWG - copper) and properly terminated in the charger. The only variable left would be the fuses/panel/service and existing connections on the line side. As stated before, your existing service, meter enclosure, and fuse panel is in disrepair and it is our opinion that it needs replacing. Electrical connections and terminals that are corroded and or loose and not torqued to original specifications can cause significant resistance in conductivity and therefore result in higher power consumption."
I feel the kWh charge you have been told by the electricity company is not the whole story, as it does not seem compatible with average electricity costs in your area. Is it backed up by the information on your invoices?
The electricity company seem to have given you the base level rate (GSC charge) of 13.2 Cents per kWh, but from what I see, other charges are normally added to that (for every kWh unit you use, eg: transmission charge ~4 cents, Distribution charge ~5 cents, System improvements charge ~ 1 cent, etc. etc.
See: Electricity - https://portal.ct.gov/OCC/Electricity/Electricity/Electricity
If this is relevant to your situation, you should be paying between 21 and 27 cents per kWh, which is less than I pay here in the UK, and more consistent with the billing for the EV you are receiving. Taking Julie's sums, a full charge would be 81.25 (kWh) x $0.23 = $18.7 for a full charge (or up to $22 at the higher average price below).
I really don't think there is anything wrong with your electricity supply, I just think that the pricing structure has changed so much since Covid that you cannot make comparisons with what costs used to be!
I just e-mailed Emporia and if or when they respond I will post it. My main concern was how is it possible if i keep charger powered up but not using it tp charge ,how in the world can my charger draw so much power.
Yes, apologies, I was thinking about costs in general.
It would have been helpful if your electrician had put a clamp ammeter on the lead to the EV charger while he was installing it, and measured the quiescent current it takes. I wonder if he would be prepared to return and measure it, since you are having this problem. That would show if the EV charger is responsible..
Emporia sell a comprehensive energy monitor that can monitor all circuits in a house, but it's costly. I wondered if an inexpensive single channel device might help diagnosis.
This might help to indicate if there is a problem, but I suspect it may not be particularly accurate:
As an Amazon Associate we earn from qualifying purchases.
Reply to the thread, titled "Odd E.V. home charger question" which is posted in UK Electrical Forum on Electricians Forums.
