ssizen
Hi all
Some advice, thoughts, ideas sought please. Recent install in our house, seperate CU for outside supplies (some SWA feeds to garage, etc), one circuit is a 6A RCBO to run quite a large pond pump, this was tripping the old CU main RCB but that was located to water in the connector for the pump cable into the SWA that feeds it, that was fixed. Now the pump runs for about 5 mins then trips, there is no reading of any short at all between Live / Neutral and Earth before or immediatly after the trip, the multimeter shows an open circuit.
Any ideas? Could it be shorting with load? Or maybe the 6A is not large enough? The pump is a submersible but quite hard to get at so it will not be easy to lift that and check / determine the rating, will have to of course if it cannot be resolved but thought best ask the group first
Cheers
shaun
Cheers
shaun
