Odd panel configuration? | on ElectriciansForums
Discuss Odd panel configuration? in the UK Electrical Forum area at ElectriciansForums.net
JFarmer22
Indiana
I purchased an old farm property and am have been going over what would be the best approach to tackle this job. The house has been in use by myself only for over a year with no issues (fires) yet and it is wired for 100A service/#2 wire. I don't want to push my luck so I am going to work on the replacing the basement panel (which has had moisture issues, thus all the rust), but my main concern is how they had this wired. Am I ok to replicate the double tap on the main lugs in the basement seen in picture #2 or is that a no no?
My new panel only has lugs big enough for 1 wire on each leg, so I technically cannot fit two #2 wires like it is currently. Am I ok to install the 'staircase' double lug to run the wires upstairs or is there a better way?
Also, is the upstairs panel 'technically' a sub panel or remote panel?
Please share any other concerns/comments/code violations as well so I can address these issues.
[ElectriciansForums.net] Odd panel configuration?
View attachment 61455View attachment 61456View attachment 61457
Jfarmer22 that panel is terrible. I think you might need to hire an electrican to help. Yes it needs to be replaced and the wire colors are a bad violation with even your live wires are white. I also didn’t see no ground because everything is meek white. No you are not allowed but 1 wire per lug. If you sub panel is 100 amps also the wires should be # 2 wire. There are 2 black wires hooked to the main buss in the sub panel without short circuit protection. That panel is so dangerous you have a lot of work ahead of you and the main panel needs some cleaning up.
Reply to Odd panel configuration? in the UK Electrical Forum area at ElectriciansForums.net
There is nothing inherently wrong with this part of the layout. There is another option that you may want to consider. Those supply conductors...
I think there is a little truth in what the guy in the video says, but he makes more out of it than he should. A N-E fault on a circuit protected...
