off peak consumer change | on ElectriciansForums
Discuss off peak consumer change in the Talk Electrician area at ElectriciansForums.net
sparkyork
got an off peak consumer unit change to do 2moro, shouldnt take long only 3 circuits on it. thing is the board aint likely to be live with it been off peak so how do i measure Ze and get Zs results, am i to get Ze by enquiry and Zs by measurement??
cheers
Cant say for sure but yes you must be able to (i think)
you'll have to let me know 2moro
Mark
You will be able to get Ze at that point and then R1+R2 at each circuit giving you Zs
if you cant over ride the clock
Mark
cheers yeah ill keep ya informed, if its one of these digital meters i dont think therell be a way of switching it on, otherwise would you be able to get cheap rate electric during the day?? i could always pop the "cough" "cough" seal on the meter and gain access to the mains to get Ze, and like you say just measure R1 R2
Some of the digital clocks have an overide button to power them up, if its one of those and the seal is missing from the meter (as they always seem to be when i get there) then its easy, if there are two meters one normal and one off peak measure ze at the powered one as it will be the same as the off peak, or you can always power it up by swapping the tails if the seal is missing on the main fuse.
markaj
yeah it was a digital meter but was no obvious way of telling how to liven up the off peak tails, i just swapped the off peak to peak connection and did it all that way.
Don't think you can as it will be sealed by electricity supply company.
If you could switch it on the you could get off-peak electricity durin normal hours.
You cant override a time switch for the reason above. They are set and sealed by the meter fitter. The modern meters incorporate a time clock in the main meter.
Reply to off peak consumer change in the Talk Electrician area at ElectriciansForums.net
If two tariffs are sufficient, and you don't need too many ways, you can easily add an SPD kit to the Fusebox F2014DT dual tariff board. The only...
Part III:). I think I have clarity-having spoken to my electrician who installed my heaters, he said that the part of my fuseboard that is...
2 3 4
