Off Peak heating arrangements | Page 2 | on ElectriciansForums
Discuss Off Peak heating arrangements in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
The small cables from the cut-out are the live and neutral to feed the time switch, normally 4 or 6 mm, the smaller black is a switched neutral to change the meter from low to normal rate, but the first red should be 25mm, as it is the load feed to the time switch from the connector block.
Reply to Off Peak heating arrangements in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
If two tariffs are sufficient, and you don't need too many ways, you can easily add an SPD kit to the Fusebox F2014DT dual tariff board. The only...
What makes it a lack of space? I’d say to the customer to dismantle a cupboard or whatever to creat the space you need for the extra equipment...
