Off the gas grid ... | Page 2 | on ElectriciansForums
Discuss Off the gas grid ... in the UK Electrical Forum area at ElectriciansForums.net
Dustydazzler
Supporter
V.Nearly Esteemed
Surrey
Really ... how likely is this to actually happen
There was something I caught on the radio the other day... about using hydrogen instead of natural gas. I was only half listening, but I think they can do this already... and convert existing boilers to use hydrogen, similar to the town gas to natural gas conversion I imagine.
We just need to work out how we can produce enough hydrogen without using fossil fuels ?
In my 2 bed flat... I averaged 9.7kWh per day for the last 12 months... that's all electric, no gas and no EV charging.
so a flat is likely to use less heating than an average house.
what do you average over the winter months?
I personally use 2 to 2.5 x as much over winter as i do in summer.
your consumption is something to be proud of.
but is in my opinion no where near the national average.
[ElectriciansForums.net] Off the gas grid ...
Thanks... I also use a fraction of the national average for water consumption too... I think it was living on a boat for a while that did it... when you have to make your own water and electricity, you tend to be careful how you use it !
My quick thought - Leccie Cars and Leccie Heating may be a “quart in a pint bottle” with our existing buildings and infrastructure. We get home, plug in NoddyCar, turn on the heating and listen to the distant groans of large rotating machines slowing down :) ..
I think heat pump are the way it will be going, air source or ground source. The price to buy them is already falling alot and with gas being phased out more manufacturers could pop up and prices fall. In a heat pump some electricity is used to run a compressor some valves and control gear so much much less electricity than a heating element.
I dont have gas at my house and my house is heated by logs, but i cant imagine that being the future
Maybe economy 7 will be re-promoted (with some new better storage heaters) (works absolutely fine for water, thats how mine is heated) , and with the plans to commission a new nuclear power plat that means more surplus electricity at night time. With electric cars also charging over night perhaps our useage patterns will shift, Also in the past gas central heating was less common and many homes had electric heating normally storage heaters did the grid cope then? Although at that time a open coal fire was alot more common for a heat boost also
To make hydrogen you need electricity and seawater. Hydrogen production is an ideal way of using surplus electricity from wind turbines when demand is low.
Yeah... electrolysis... I remember doing that at school and hearing the pop! as you ignited the hydrogen you'd captured in the test tube.
But I don't think that process is currently used for commercial production... it's made from blowing high pressure steam into natural gas... so it's not really that 'green'.
I think it's interesting that 'coppicing' (growing trees specifically for making firewood) is actually very environmentally friendly... as the CO2 that is released when they are burnt is simply the CO2 that was absorbed over the last 7 years of the trees growth cycle. The only drawback with this is that each house would need a few acres of coppice...
"Could" = won't.
(Apologise for accidentally reporting your post)
Yes it's going to be the same old scenario as the diesel car fiasco, you must go diesel for you next car as it environmentally better for the planet, then once you do, increase the tax on the fuel, Oh and while I am at it I will sell off all our Gold reserves.
Reply to Off the gas grid ... in the UK Electrical Forum area at ElectriciansForums.net
Capped gas pipe begging oven Hi all. Hope you are well. So I fitted a new induction hob today for my father and whilst the old hob was off I saw...
Steveuk
