Oh no not ammendment 3 again | Page 3 | on ElectriciansForums
Discuss Oh no not ammendment 3 again in the UK Electrical Forum area at ElectriciansForums.net
Pete999
Northampton
1st day back at work today after a long lay off nothing much to do so the internet beckoned. I decided to have a look at Amd 3 and was amazed at some of the disinformation coming from some of the Distribution board manufacturers, I read and printed off a copy of amd3 from the IET and it clearly states " domestic consumer unite shall be made of non combustible or a not readily combustible material " Where as virtually the same document from a well known distribution board maker (beginning with H~~~r) saying that the domestic CU must be made from NON COMBUSTIBLE MATERIAL scare mongering or what?. I appreciate it's a work in progress but someone ought to take these people to task, we should wait until Ammendment three is ratified before jumping to conclusion, what are your thoughts?
I agree with you young man . There are already fuse boards on the market that will be ok to use , so why not tell us ones that can't be used . To easy ?
I was in my local wholesalers yesterday (independant) and there was a BG rep trying to get them to sell his gear. I asked him about this plastic/metal CU thing. He said nothing is concrete yet and they are working behind the scenes to get it dropped. I took this to mean current plastic BG boards will not be ok!
As has already been stated above, they would make all CU/DB plastic or metal, far safer by calling for the reintroduction of twin connection screws/clamps on all main switches and protection devices.
Oh and BTW someone mentioned Wylex wooden backed 3036 CU's, Wylex have never made a wooden backed CU, they made wooden frame ''Open back'' CU's. But he was right about never seeing one catch fire internally, nor have i and i dare say no-one else has either!!
I found one that had obviously had a nail for a fuse or something at some point and there was a hole burnt entirely through the back board and the old fuse carrier (safely protected with insulation tape!) was significantly the worse for wear, but the wooden surround was not harmed at all and the rest of the CU seemed OK, just lucky I was changing it.
Looks like the M&Q regs were right from the outset, everything metalclad.
We all know this is a load of b0££oX. So why perpetuate an unsubstantiated rumour?
Wait until the yellow book arrives, in the meantime STOP PANICING!
At one time electricians were noted for their logical approach to things. Headless chickens is more apt nowadays.
I may be missing something here but in the images Iv'e studied relating to consumer unit overheat/fires.
Its the internal components that show heat damage and bugger all to do with the enclosure being plastic, (have a look yourselves)
Most of these problems are down to loose connections from what I see.
Its the 15th all over again, and back to the days when a terrified young mother is walking her toddler passed a building site to be confronted by a loony sparky with his shiny new copy of the regs book a 10mm bond and clamp that he instantly attaches to her little one's buggy.
Consumer Unit Fires | Burgoynes
Reply to Oh no not ammendment 3 again in the UK Electrical Forum area at ElectriciansForums.net
