Ohm's law and Current Carrying Capacity recap.. | on ElectriciansForums
Discuss Ohm's law and Current Carrying Capacity recap.. in the UK Electrical Forum area at ElectriciansForums.net
Reply to Ohm's law and Current Carrying Capacity recap.. in the UK Electrical Forum area at ElectriciansForums.net
You don't normally see It in the equation. What you would normally do is apply correction factors then select a cable/conductor for Iz from It...
In the current book (18th, amendment 2) it is under regs 433.2 and 434.2 In most domestic situations the usual approach is the whole circuit is...
