Guest viewing is limited
View the thread, titled "Can anyone give me the answer and source for this question on current carrying capacity" which is posted in Electrician Courses : Electrical Quals on Electricians Forums.
Hello I just need to know the correct order and a source which shows me that it is that order please
When calculating the current carrying capacity
Is the correct order
Ib ≤ In ≤ It ≤ Iz
Or
Ib ≤ In ≤ Iz ≤ It
Niceone
Ib ≤ In ≤ It ≤ Iz
Or
Ib ≤ In ≤ Iz ≤ It
Niceone
Worth having a read
Upvote 0
Worth having a read
Thanks for your reply, I have read this before and it shows the formula without (It).
The reason that I’m asking is that I’ve been told by my tutor that the order that I think it is is incorrect but without giving me a source
The order I think it is
Ib ≤ In ≤ It ≤ Iz
The reason
First you calculate your design current
Then select a safety device that is equal or larger than that current
Then you find the tabulated current by applying factors such as grouping, insulation etc
Using this It ≥ In/CgCaCsCdCiCfCc
This is now the actual current that will pass through the cable
Iz value when larger or equal to (It) will correspond to a csa that will take this current
All these values come from bs7671 tables
This makes sense to me but I’m happy to find out I’m wrong and do it correctly, all I want is a source that shows me that I’m wrong
Upvote 0
Ib ≤ In ≤ It ≤ Iz
Or
Ib ≤ In ≤ Iz ≤ It
Niceone
Ib ≤ In ≤ It ≤ Iz
The reason
This might make it clearer to what I mean and why I’m asking
Upvote 0
You don't normally see It in the equation. What you would normally do is apply correction factors then select a cable/conductor for Iz from It they are just asking you to include It. Iz is not necessarily the same as It for example It could be 10A and Iz 15A. Remember It is not the current that will pass through the cable but the current carrying capacity of the cable required due to external influences, for example In is 16A so your cable (Iz) must be rated at 16A or above and without correction factors this is as read but correction factors can "squeeze" the rating of the cable down to say 13A hence a larger csa is required, Ib does not change.
Upvote 0
Reply to the thread, titled "Can anyone give me the answer and source for this question on current carrying capacity" which is posted in Electrician Courses : Electrical Quals on Electricians Forums.
Electrical Courses
