OK to add a 50 AMP breaker in this panel? | on ElectriciansForums
Discuss OK to add a 50 AMP breaker in this panel? in the DIY Electrical Advice area at ElectriciansForums.net
ted3511
Oklahoma
OK to add a 50 Amp breaker in this panel for a 220V EV Charger? Maybe swap some single 20 Amp breakers for dual 20 amp breakers?
Can I add a 50 AMP Breaker to this panel for a 220V EV charger? Maybe double up some of the 20 AMP ones to make space? I have 200 AMP Main Breaker. (see attached pic) Thanks!!
  • [ElectriciansForums.net] OK to add a 50 AMP breaker in this panel?
You should be able to add a 50 amp double pole breaker but it would have been better if you took a picture of the actual panel. I’m guessing that you could use small tandem breakers.
Thank you for your response! Here is a pic of the panel:
Reply to OK to add a 50 AMP breaker in this panel? in the DIY Electrical Advice area at ElectriciansForums.net
Yes you will need to install # 4 wiring times 4 for your 2 hots, 1 neutral and 1 equipment ground. As for keeping the grounds and neutrals...
A 2 pole breaker will have a bar between the 2 breakers and the slim line breakers that you are referring to are just 2-15 or 20 amp single pole...
