Old ceiling light wiring clarification | on ElectriciansForums
Discuss Old ceiling light wiring clarification in the Lighting Forum area at ElectriciansForums.net
Norton
Hi there.I was about to change a ceiling light for my daughter flat,to a drop down so she can put a lampshade on.The fitting is quite old and the wiring I found can be seen in the photos.There are 3 reds twisted together,then 3 blacks,of which 2 are in 1 connection and the other in another connection point.Could someone please describe to me how they would go into a modern light fitting.Many thanks
  • [ElectriciansForums.net] Old ceiling light wiring clarification
Three reds into the middle terminal.
Two blacks into the blue side.
Single black into the brown side.
Cut the twisted ends off.
That new pendant you're fitting seems to have damage to the suspended flex - treat yourself to a new one, they're only a couple of quid !
well spotted, brilliant reply, a potential reply post of the month there. I didn't spot it at first, but I am old lol
Reply to Old ceiling light wiring clarification in the Lighting Forum area at ElectriciansForums.net
Thank you, both. Seems like common sense may have prevailed, and the fellow is indeed going for one of the modern mirrors you mentioned...
Thank you all for your replies and suggestions. I will try to follow up on each one and find a suitable solution. many thanks all
