Old colours | on ElectriciansForums
Discuss Old colours in the UK Electrical Forum area at ElectriciansForums.net
kingeri
Yorkshire
I have acquired a fairly large amount of old colours T&E, all brand new rolls. I am considering what to do with it. I believe it can still be used if you sleeve brown and blue, is this correct? Seems a bit rough though somehow.
I have also considered just scrapping it, but don't think I can be bothered stripping it all.
Finally, I see it is going for big money on ebay, but then I can imagine some DIYer buying it to make it look like old work and killing himself.
Any thoughts?
IIRC you can't install old colours and still comply with BS7671.
BS7671 Appendix 7 syas that sleeving etc is permitted. I'd go for that and put a mixed colours sticker on the CU.
Not sure what/if you paid for the cable, but if there's profit I'd be using the eBay option. Caveat emptor:wink_smile:
Or just scrap it as household cable....
Bugger stripping it, I've found you don't loose much doin it that way by the time you take off the insulation weight and the --- of a job stripping it lol
If somone put a load of old colours T&E in my house I cant say I'd be best pleased. Any electrician doing an EICR, for a potential buyer for example, would probably assume that the rewire that is supposed to have been done, has in fact, not been done at all. I'd just flog the stuff.
what really gets up my nose, apart from the gross stupidity of these new colours anyway, is that FP200 now comes in brown/blue. since when did a regulation come in that 24V d.c. cables should be any colour other than red (+), black(-).?
and if it’s sleeved correctly at each termination point?
You can use Sky Blue Pink with Yellow Dots as the insulating medium. So long as it’s correctly identified at each termination.
Do you use Brown / Brown T+E for switch drops? No you’ll sleeve the blue as brown! Now tell me, where is the difference?
Reply to Old colours in the UK Electrical Forum area at ElectriciansForums.net
Absence of correct labelling is a C3, reversed polarity is a C1 (BPG-4). You choose.
My bafflement increases. I swapped the offending light with one elsewhere on the back of the house - one of those that's on a circuit of its own...
