Old crabtree | on ElectriciansForums
Discuss Old crabtree in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
M
mogga
I know its somewhere on forum but cant find Type or Max Zs for 3781 crabtree C50 breakers the OLD aincient brown ones Can anyone assist?
3871 are type 1,2,3,4 mcb.s differen,t values to 60898
only type 3 and c are the same.
'phone Crabtree and they will tell you. Don't quote me but I think that if the amperage on the switch is in white then it is a type 2. If it is yellow then it is a type 3. They stilll make the C50 range and the 3871 type 3 has 60898 type C approval.
Rgards
Steve
Reply to Old crabtree in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Sockets will probably be ok on one, a little inconvenient in the event of a fault though, I'd probably like a 7th rcbo in. Wonder if hes linked...
7K
suffolkspark
It’s difficult to advise on an electrical issue when some isn’t very conversant with electrical terminology.
