Discuss Old Domestic Servants/Butlers call system in the Domestic Electrician Forum area at ElectriciansForums.net
Push buttons in the rooms definitely. Not sure on the bell or battery - will have to have a look when I'm back there next week.There's a larger one for sale on ebay with photos of the back.
Looks like it's solenoids that wave the flag, and maybe ring a bell outside of the box.Antique butlers and servants bell indicator box c1920 | eBay
<p dir="ltr" style="margin-top:0; margin-bottom:0;">This superb antique Servants Call Box totally original and measures 16 inches x 11 x 3. I have not tested it but it should work and I will gladly test it for anybody interested.That said it will look great hanging on the wall in any...www.ebay.co.uk
Probably low volts D.C with a battery somewhere nearby and push buttons in the rooms
Doesn't work but I've not looked into why - I'd assume it's still all wired up as much of the property hasn't changed since it was built in the 30's. The push buttons are still in place, as is the box pictured.It will be fairly simple to work out. Does any of it work, or still wired up?
Normal push button like a doorbell push in each of the rooms, 2 core bell wire back to the bell box.
Might need to determine if AC or DC, but will be ELV.
Each button and signal in parallel, and one bell in series with the return.
Are these electrical, or wires and pulleys?Reminds me of the bell systems they used to have in some of the National Trust houses I used to look around
The voltage won’t be as exact as it would be nowadays…. Will possibly work from 9 up to 24vFound this on the interwebs:
Nothing to it really, the only mystery is what kind of supply voltage it needed.
In the absence of any other clues I'd probably start experimenting with a 9v battery.
The solenoid voltages are not going to be super-critical especially given the momentary nature of their use, and the bell could always be replaced with a known voltage unit.
Some small setups use even less. I've seen 2 systems designed to use 3 1.5V flag cells, another used 5.The voltage won’t be as exact as it would be nowadays…. Will possibly work from 9 up to 24v
The flags on these are usually just pulled by the electromagnet when the call button is pushed, then when the button is released the flag springs back and continues to swing for 30 seconds or so. Posher models the flag drops down permanently and a button has to be pushed to activate a separate reset electromagnet.I'm assuming that gravity is what makes the flag drop down again?
Reply to Old Domestic Servants/Butlers call system in the Domestic Electrician Forum area at ElectriciansForums.net
