Old double light switch wiring | Page 2 | on ElectriciansForums
Discuss Old double light switch wiring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
i see what you mean. the 2 wires into the L1 terminals ( as ID'd by richard ) seem to be from separate cables. the top one appears to be a black sleeved red. would be good to see a pic of the cables entering the back box which should also show the presence ( or not ) of cpc's.
pete, you got parkinsons? :(
Very funny, no Mate I thought I had better not post what I had written so I erased it, if that's what you were referring to.
My gut feeling is that at some point in the past, someone has changed the switch to the current one and mistakenly connected the red cores to the wrong half of the switch. It's probably working because (if it's wired how I'd do it), they are both live feeders from the relevant light fitting.
Are the 3 cables at the 2 way a 3 core from the other 2way, and the 1 way wired as a L and S/L from the light operated via the 1 way?
Reply to Old double light switch wiring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Thanks again for your help, now solved 👍
Thank you so much for your help with this light work perfect now thank you again much appreciated
