Old electric underfloor systems....one for the older farts on here! | on ElectriciansForums
Discuss Old electric underfloor systems....one for the older farts on here! in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
FatAlan
Trainee
Nearly Esteemed
Supporter
Surrey
[ElectriciansForums.net] Old electric underfloor systems....one for the older farts on here! In the process of buying an old cottage. Apparently there is an old underfoor heating system that dates back to the sixties so just as old as me.
Can you tell me what this is? See piccture attached. Is it some sort of transformer? What ever it is it makes a good humming noise.
Very noisy if it is. Sort of assuming that as there appear to be two meters it's an economy seven set up.
Yes it'll be a contactor which brings the heating on during the low rate period.
The floor is effectively used as a large storage heater in these systems.
Would be interesting to know how and what type of heating element is incorporated into the floor.
Reply to Old electric underfloor systems....one for the older farts on here! in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
On putting a date on old cables the makers used to use a letter system. This was certainly used on pilc cables and sometimes in lead sheathed...
There's a church in a town near me that has solved the heating problem for most days by building what is essentially a large timber and glass...
