Old fuse boxes and mineral cables from 60s, is a complete rewiring required? | on ElectriciansForums
Discuss Old fuse boxes and mineral cables from 60s, is a complete rewiring required? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
W
wtlh
Hi,
We have just bought a flat that was built in the 60s. We had three sparks coming to the property and looked at the electrical systems as we wanted to install new storage heaters in the bedrooms. The indication we got is that the main circuit in the flat has not been changed since the 60s, and bits and pieces, such as the electric shower has been added on later. There are very few consumer sockets in the rooms.
The recommendation I got from the sparks has been rather different.
One recommended me to do a proper test first.
The second one said that the 60s wires are made of good quality materials and they should still be okay. But adding additional storage heaters will be difficult. He recommends just ordinary electrical heaters. Only the fuse boards will have to be replaced.
The third one, said mineral cables are used to connect the power from main, which uses the copper casing as earth, and it is not up to the standards of current regulations. He said that it will just be a waste of money to do a full test, because in his view the test will just confirm the fact that wiring needs to be changed anyway, and the flat will fail an electrical inspection just from what he has already seen. So he suggested a complete rewiring.
Ideally, I guess a complete rewiring will solve all the problems associated with the lack of storage heater in the bedrooms and the lack of sockets. However, obviously it will also cost a lot more. I am just worried that if we go for the cheaper option of just adding the E7 line and storage heaters into the bedrooms, then some other problems could prop up when we redo the kitchen and bathrooms for example, or if we try to install newer appliances, and it could end up being more expensive.
Your advices would be much appreciated.
Cheers
Take electrician #1 He's the only one who has given good advice.
#2 is talking rubbish because 60s wiring could be breaking down. There's only one way to tell
#3 is talking rubbish because mineral insulated cables are not used in a mains supply. At least not one that I've seen in 34 years in the trade. If MI cables are used in an installation, if they are done properly they will outlast just about anyone on this forum
#3 is also talking rubbish because he's not thinking about the benefits of a test and what that will tell him. He's only seeing the ÂŁ signs of a full rewire (which you may well need btw)
Give him a call and ask him how a rewire of your house will deal with these supposed DNO MI cables.
When rewiring, the DNO cables are not touched by us.
Tell you what guys, that's the best one I've heard in years. MICC not compliant with current standards PMSL
you got turbo fingers, trev. ???? totally agree with your post. test first, then remedy as required.
Hi Guys,
Thank you very much for the quick reply. This is the type of advice I need!
I will definitely call up and get the test done first.
Do you know what the test will an will not tell me? Will it tell me which wire goes to where, and what are the maximum load capacities in the wires etc?
Cheers
It will tell you nothing really, it will tell the electrician all he needs to know about the condition of your installation though. It's then up to him to talk you through it and explain what everything means.
it'll tell you all that and more. the electrician will be able to advise on whether or not you can add extra loads and where.
Thanks! So I should ask for a "EICR" test, correct?
Yes - but ask him 2 questions:
1. How long does he anticipate being in the flat
and
2. How much he charges.
A proper EICR should be about 3 hours on site and 1 to 2 hours filling forms etc at home. Anything less is probably not worth doing and if that's the case get another spark to quote for an EICR.
Out of interest where in Berkshire are you? The border isn't far from me!
and
I am in Windsor.
If the flat's been wired in MIC it might be the walls, floors and ceiling are all concrete with the cabling embedded - got several blocks like that round my way. Chasing new cable into solid concrete isn't impossible, but it's not much fun, either, for contractor customer. If you have more socketry/circuitry installed you may be looking at surface-mount in trunking.
pj
pj
I was under the impression you are not always allowed to chase ceilings etc because it can weaken the strength feel free to correct me.
depending on the size of the rooms and if you dont want surface then a possibility is having it boarded straight over the concrete but you will lose a little room space but imho a much better finish if cant chase
I think the floor and the ceiling are concrete. The outer walls and the wall between the living room and bedroom 1 are brick (told by surveyor). The rest of the walls produce hollow sounds when I knock on them, so they are probably plasterboards. The ceiling when you knock on it sounds hollow throughout the flat. I am suspecting it is a false-ceiling board fixed onto the concrete above via wooden beams.
The neighbours did a rewiring about 10 years ago, and everything is hidden, no trunking at all. So fingers crossed that we will not need trunking.
Reply to Old fuse boxes and mineral cables from 60s, is a complete rewiring required? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Pretty common for lights and sockets to get a Re-wire and the Eco7 circuits usually storage heaters /water heater to remain left as was. As for...
The challenge that you have with this is that you've no confirmed start point. Because you have a lack of an EICR you don't actually know what...
