old garage door | Page 2 | on ElectriciansForums
Discuss old garage door in the UK Electrical Forum area at ElectriciansForums.net
DDnot
Hi! I am doing an installation for a garage detached to a house. The garage is going to be converted within a few months into a living area. There are no water or gas services. Nothing really to bond apart from old metal garage door which will be removed during the conversion work anyway. There are no cables around the door or close to it. Do you think I should earth-bond the door temporarily? According to the regs I guess I should. What do you think? By the way the installation is completely separate from the main one through henley block and has a new consumer unit with RCD.
If it's a metal frame in contact with the general mass of earth, and as such is classed as an Extraneous conductive part, then why can't it be bonded pray tell? Additionally, not bonding it because "it was coming out at some point" would be no defense if someone were to get hurt in the meantime.
What the OP has not yet ascertained, it seems, is whether or not the framework is an ECP.
exactly...
If it is being removed why would you want to bond it?
Another one who does not know what their doing after a 5 day course I think.
I don't think you can ever assume anything. If it does need bonding and the "conversion" was to take a year or 2, how would you make the decision not to bother? My philosophy is to bond anything that needs it, then remove it when it's no longer needed, although we still haven't established whether it even needs it yet, as the op seems to have lost interest !!!
Reply to old garage door in the UK Electrical Forum area at ElectriciansForums.net
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
Yes you will need to install # 4 wiring times 4 for your 2 hots, 1 neutral and 1 equipment ground. As for keeping the grounds and neutrals...
