Old intruder alarm | on ElectriciansForums
Discuss Old intruder alarm in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
London
Hi there
I have been on a job to fix intruder alarm.
Alarm Texecom 1995 very old alarm .
Owner 96 years oldman wanted to replace battery inside the panel. Unfortunately when he took cover down battery fell pulling other cables from terminals. I’ve managed to terminate cables back as I thought they need to be. Now I need help with the siren outside + small siren near the panel. How do I connect them . Obviously siren + and - tamper but terminals are different in this old panel . Can someone who done such an old panel help me? Look on the picture terminals for sounder S,D,C,B,A I think. The small siren with wings like a fan. Thanks for any advise.
[ElectriciansForums.net] Old intruder alarm
D is the negative for the SAB hold off supply
In the bell the 0v is linked to one side of the tamper switch and then the other side goes back to C in the panel which is the tamper return
C & D are linked in the panel to stop a tamper being indicated so you need to check the external sounder has a correctly connected SAB
Reply to Old intruder alarm in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi everyone, first post here and in a bit of a pickle... Newly qualified out in the big bad world... I have a job 4 hours from the office so I...
If you do not have an external sounder in circuit you will have to link out the tamper return to negative.
I’ve recently moved into a property with a Texecom premier elite system. I’ve been given the engineers code and have read up on the alarm. It...
Just an heads up here, any expansion or addition to the control system of a Fire Alarm should be suitable for the job in hand and I don't mean...
Oddly enough, I do actually have a wind-up megger! It sits on my curiosity shelf beside my AVO which, sadly, I can't get to work despite buying an...
