old mem consumer unit, help plezzzzzz | Page 3 | on ElectriciansForums
Discuss old mem consumer unit, help plezzzzzz in the Australia area at ElectriciansForums.net
M
m25maintenance
guys im replacing an electric shower like for like, the old shower was 9.5 kw, but was only on a 32 a mem type 1 321 qeb mcb, i told cliant it should be protected by a 40 amp breaker, trouble is the board is oldish and i dont know what breaker to fit,,,, also no rcd protection on boaed, are there any mem rcbo that will fit that board,tanx
230v EU!! as said above... however my property enjoys a nice helping of 244V !! i would measure the supply to see what you actually get! some times you can be suprised..! i once saw a reading of 252v that dropped off in the day to 241....!! hmm interesting
ya if it's up over 240v you can add a kilowatt to the load- best check supply voltage as it could affect mcb/cabling
as you said they're marked on the box 8.5/9.5 for 230/240 that's why i assumed you were mostly still on 240v in the uk
DSO here is allowed 10% tolerance (23volt either side of 230v) -but that would be extreme
I've had a 10.5kw shower wired in 10mm, for 10 years...on a 32a rcd breaker...never tripped yet..its only on a 32a cos at the time i had one spare...never got round to changing to 40a, no need to now
hmm 10.5kw is a big shower-you sure it's that big :confused:
it should trip over time anyhow -according to the characteristic curve of the mcb
i've been miscalculating slightly anyhow-9.5 at 240v =<40amp and 10.5 at 240v =<44amp
i was a bit confused as the uk nominal voltage is now 230 but appararently it can be 240(and also above or below with tolerances)
Have you considered checking if there is any significant earth leakage and if not, protecting the whole board with a separate rcd in the tails.
you might just get away with the 6sq on that-it's borderline around the 9kw
down to the install method and length of run really
10sq is usually a safer bet anyway
Reply to old mem consumer unit, help plezzzzzz in the Australia area at ElectriciansForums.net
I have to agree with Baldelectrician on almost everything he says except one ! I wouldn’t be walking away I’d be running lol. Definitely if your...
