B
bonn1ett
Hi everyone,
I am fairly new in the trade and wondered if anyone can throw some advice my way. I recently went to a fairly old property as all the lights had gone off due to a lamp blowing in one of the light fittings which in turn blew the 5amp fuse wire in the board. Apparently this had happened a few times with the lamp blowing/popping out of its fitting?
There is one lighting circuit and hence one 5amp fuse for the whole house - upstairs and downstairs. I recommended to the customer (elderly lady) that the fuse board needs updating and that two circuits are needed for the lighting - upstairs & downstairs. The customer is happy to have a new consumer unit put in but does not want any re-wiring done - obviously if there is any faults found on the existing wiring then i will recommend strongly that the work be carried out.
My question is this, with regards to only having the one lighting circuit, could i perhaps use a 10amp breaker as opposed to a 6amp to cover the whole house - as long as the cable rating is higher than this (not sure if its 1mm or 1.5mm being used, need futher investigation).
any advice would be great
