View the thread, titled "Old re-wireable fuse board change" which is posted in Australia on Electricians Forums.
B
bonn1ett
Hi everyone,
I am fairly new in the trade and wondered if anyone can throw some advice my way. I recently went to a fairly old property as all the lights had gone off due to a lamp blowing in one of the light fittings which in turn blew the 5amp fuse wire in the board. Apparently this had happened a few times with the lamp blowing/popping out of its fitting?
There is one lighting circuit and hence one 5amp fuse for the whole house - upstairs and downstairs. I recommended to the customer (elderly lady) that the fuse board needs updating and that two circuits are needed for the lighting - upstairs & downstairs. The customer is happy to have a new consumer unit put in but does not want any re-wiring done - obviously if there is any faults found on the existing wiring then i will recommend strongly that the work be carried out.
My question is this, with regards to only having the one lighting circuit, could i perhaps use a 10amp breaker as opposed to a 6amp to cover the whole house - as long as the cable rating is higher than this (not sure if its 1mm or 1.5mm being used, need futher investigation).
any advice would be great
but its not a wrong option is it
i would always give the cheaper option as well and try and explain the good and bad in both options after all she is an old lady
If anything...the old rewireables would be better (characteristic wise) than the B type....but as has been said already....its the convenience factor n all....
suggest that if the lighting is all 1 circuit, dis the feed between downstairs and upstairs lights and feed a new T/E to the upstairs
My lights are all on one circuit (1970s build house) and can't see the point of splitting them. All the hassle of boards up, making good, etc. I can't remember the lighting MCB ever tripping (or the 3036 fuse before it for that matter) in 15+ years. That's mixture of part tungsten and part CFL lamps used.
Daz
Reply to the thread, titled "Old re-wireable fuse board change" which is posted in Australia on Electricians Forums.
