C
Chrishands
Hi I have an old Wylex Db serving my house. It is basic with MCB's and protected by an added RCD box on the incommer at a later stage.
Iv'e had a few concerns with it.
1.When i put the lighting circuit on the DB would buzz, i think i found it was the Dimmer switch, which i've Got rid of,in place of a normal 1g1w switch
However 2. When somebody uses the shower, the 40A breaker serving it gets HOT, just as hot as clothes that have just come out of a tumble drier, not scorching but Hot. Any Ideas what this could be? The MCB is Hot not the Female part it pushes into just the push in MCB.
When i fully qualify in another year i will be looking to change it as its way out of date and out of spec with 7671, but untill then i would like to know the possible causes, as it could potentially cause a fire.
I have checked it is not loose and not vibrating.
