On the dreaded 2394 - 2395 Course | on ElectriciansForums
Discuss On the dreaded 2394 - 2395 Course in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
C
Chris Harrison
Hi all New to the forums but been working in the industry for 10 + Years now have my level 3 and 17th edition. Employers just put me on the inspection and testing course, not sure what to think at this moment on my second day. Initial letter says 5 days but looks like after this week will have to go in for a further two more tests, seems like they throw quite a lot of content your way in such a short amount of time.
I like to think i have had a lot of experience with testing and inspection, done quite a few periodic inspections with 30+ Distribution boards and probably the most experienced in the class but i'm still bricking it!
Was wondering what these qualifications will actually mean for me or allow me to do if anything extra, i don't see what my employer gains from sending me on this course?
P.s. I don't think city and guilds know what they are even talking about sometimes, get this sample question for instance:
Increasing the length of a cable would NOT affect the;
a. Voltage Drop
b.loop impedance
c.rating of the protective device
d.insulation resistance
C&G's correct answer was C announced the tutor! I don't have high hopes for the real life test where i can put in the 100% correct answer only for it to be wrong.
C is the correct answer, though... (in theory, anyway). Longer cable increases the VD because V=IR and R will be bigger (more cable). The loop impedance will be bigger for the same reason. And the IR will be lower as you've got more insulation in parallel. How can putting a longer cable in change the rating of your fuse/circuit breaker? So C is your answer.
It is a lot of info to take in over 5 days. If you've been doing it for 10 years, you will be well up to speed on the techniques and practical aspects. What you'll have to get your head around is calling everything by its proper name. It's not a megger, avo, or even a continuity tester: it's a low-resistance ohmmeter.
Read GN3 cover to cover. Then repeat.
Good luck :)
Upvote 0
I read the question, and my answer is also c.
The critical word in the question is NOT.
If you increase the length of a cable then a, b and d are all affected.
C&G often word their questions in an obtuse way, so you gotta read it carefully!
Upvote 0
They do! They go on a special technical course on how to set questions in such a way that you can't skim-read them, you have to read them carefully and work out what exactly they're asking.
It's called the "sneaky gits" course, I believe...
Upvote 0
D. is the correct answer.
Cable length could be 1m or 200m. It is testing the insulation resistance, not the length of the conductor. The other options are all related to length of conductor!?!?!?!?!?! Although the option are all related, the key word is """NOT"""
Upvote 0
a. Voltage Drop
b.loop impedance
C. """affects""" the choice of the OPCD due to A & B. Insulation Resistance will not be effected due to the length of the cable!
Time loop impedance "affects" the designed OPCD due to length of the cable run. The answer is still D in my book. (Tin hat on)
Upvote 0
Reply to On the dreaded 2394 - 2395 Course in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Sorry if I'm being dim but there's no additional requirements for installing chargers, it's just another circuit to be installed in line with the...
I did the homestudy level 2 and level 3. You're on premesis for 4 weeks for level 2 and 3 1/2 weeks for level 3 broken up over the time you take...
Electrical Courses
