Installed an RCD shower unit today, was just a case of moving existing cable from old fuse board to the unit...we'll at least that's all it was supposed to be. Basically there's two meter tails coming from top of main fuse board switch & the Earth from Earth bar in main board down to the RCD unit. I done my insulation resistance on the shower circuit before powering it up, everything was clear. Turned on RCD...bang, blew main fuse. Slight smell coming from the RCD so I assumed it was a faulty switch, put it back & got a replacement, again when I turned it on same again!! Surely not a second faulty switch??? I tested between the live & neutral contacts after I disconnected it & it was showin' 0.24 so the second switch is faulty as well, probably should have tested the second RCD before I connected it. What is the chances of this?! Is there anything else that could cause this? Bizarre.
