One off rewire / Part P | on ElectriciansForums
Discuss One off rewire / Part P in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
East Sussex
I am not Part P registered as i work in commercial environment doing testing and inspections and currently our firms Qualifying Manager. But i am time served electrician, trained with Electricity Board as was and been qualified and experienced for 20+ years. I have a gold ECIS card as Approved Electrician. Now i know all this makes no odds whatsoever on the Part P malarky, but need your expert advice.
I dont do domestic work or certainly not since Part P arrived, but my brother has just bought his first house on a shoestring budget that needs some work! When i say shoestring i really mean no chance of paying a contractor! So muggins here volunteered to rewire the house for him etc at no cost family and all that (well he'll owe me! haha) but stupidly i agreed all this before i actually remembered Part P..!
So, whats my best option and how do i go about it? I dont mind getting registered for Part P, but what does it involve? I dont run my own business or have any previous jobs to assess and whats the cost or time scale to get on a scheme? OR is it easy to just get another sparky or firm to do the cert when i finish or is that a no-no? And final option, is the council inspect my work etc after, but no idea what that costs or where to start? Had a look at building control pages on site and totally confused, it lists several prices some for competent and some for non-competent. But not even sure which i am, well i know im competent of course, but in the "terms" am i? Daft really when my job is inspecting installations myself far more complicated than a 4bed house!
Appreciate advice here?
If you can prove to the LABC that your suitably qualified, you can get a planning consent to do the work (approx ÂŁ200 round here), that then includes a sparky the check the work on first and second fix, then they will accept a relevant 17th cert from you, However different LABCs do have different systems in place
Choices are as follows:-
1. Register with NICEIC or similar but will cost you ÂŁ300+ and you'll need to be trading and have projects to get full scope registration.
2. Submit Building Regs application to the LA and get them to supervise approve the work. Probably ÂŁ200 plus.
3. Get a Part P reg Electrician to sign of your work if you can.
4. Ignore the above and go ahead. Not an option!!!
Regards
But strictly speaking your not allowed to get another firm to sign off your work on a part p basis, however people do, most firms won't do it because it leaves them legally responsible for other people's work, but it could slip you through the net
Do the rewire and get a another electrician to do an EICR. This will usually satisfy the LABC. Thats what they tell folk to do if there "electrician" has done a runner without leaving the certs. Not the right though but its cheaper than paying LABC and its not as if your not qualified. Just out of interest....could you not fill out an EIC and slip it through the firm you work for, without them knowing?????
- - - Updated - - -
Too quick for me trev..lol
Sadly a guy did an EICR on the companies amtech last year and he got fired..! eek
Not sure we Part P registered as never seen any domestic work, although we do certify pubs sometimes, not often.?
If you're NICEIC AC then the company will be able to notify, if you ask the boss what's the worst he can say? He's not going to fire you just for asking.
From what I,ve seen lately I,d just get on with it and sod part p,put it this way if I do any work on my house it,s gonna be a case of "part what?". Since I retired I,ve seen so much crap work by so called part p sparks it,s unreal,examples are as follows.
Cables not run in safe zones,
terminal block used on lights and pushed into ceiling void,
taped joints on cables,
cables not clipped in lofts,
joint boxes under chipboard floors and therefore innaccesible,
no sleeving on earths,
no grommets on back boxes.
The list goes on,incidentally a lot of these were on diy programmes that spout on about the importance about using a registered spark.
The best one was my sons council house where the cu was labelled up incorrectly.
if this is the standard of work carried out by so called registered sparks the I for one am glad I,m out of it.
New Part P rules means that you should be able to get a registered third Party sparks to complete an EICR and notify the job through building control.
Its all here on the planning portal part p http://www.planningportal.gov.uk/uploads/br/BR_PDF_AD_P_2013.pdf look at page 9.
So the next question - do you know any Part P sparks who will do this for you to save you money on LABC fees?
There are no third party registration schemes in place at the moment so that would not be an available or legal option.
The talk to the right people at your LABC and explain your competence and that you will supply the EIC for the work, they (may) be nice and accept this.
hmmmm. you could install it and then do an EICR. you don't need to be registered with a part p scheme to do EICRs.
Reply to One off rewire / Part P in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Isn't it just a little sad that it should cost sooooooo much to LOG a few jobs to BC.... O where did it all go very wrong ? Signed Man in tights...
This situation is not uncommon and is absolutely nothing to lose sleep over. There are plenty of properties sold without the 'required' electrical...
