One RCBO killing entire board? | Page 2 | on ElectriciansForums
Discuss One RCBO killing entire board? in the UK Electrical Forum area at ElectriciansForums.net
Amr400
Sheffield
I had a 6amp RCBO feeding a 2.5mm radial ( temporary measure)
It tripped, as I expected would
But once tripped, all the other circuits went dead?
I replaced with a 16amp RCBO, powered on, and everything back to normal?
What could have caused this?
Probably been said 1000 times.
Do you really think electrical faults do not happen on "Temporary Installations" There are many regs and Statutory compliances for temporary installations. More people are electrocuted by temporary installing than permanent pro rata. I never never give advice on Elect work to anyone unless they are under my direct supervision or responsibility. I fail to understand why so called Electricians are so quick to give advice and thenb so quick to condemn others.How many of you would give advice about replacing gas fitting on a boiler.
I may offer my opinion on what's wrong but that's it. Only an opinion.
Anyhow I I think first reply mattg4321 is spot on and covers all components within that arena. Incorrectcwiringvof consumer unit
I disagree I'm afraid, his response. was not a response it was sarcasm and I've told him so, this is a forum where we can discuss issues like this, I for one would like to know what caused it and would encourage Electricians to discuss and not dismiss
50 yes experience starting with a
5 year apprenticeship 1974 to 1979
And a full 5 year one too.....not a 2 Yr heta course in a college workshop
I have installed lighting circuits in large factories and warehouses using 10.0 to accommodate volt drop using 10A protective devices, this is bad practice?
Is sarcasm really needed here? there is nothing wrong with this question the man is asking a valid. question
Not sure why you thought it was sarcasm. It sounds to me that it’s very likely that the consumer unit has been installed incorrectly - either by incorrect connections or loose/missed connections.
Reply to One RCBO killing entire board? in the UK Electrical Forum area at ElectriciansForums.net
Yup will do exactly that when I'm back down there. Thanks for the help
My thoughts exactly! Snowed under with work at the moment, so might have to pass it on 😬😬
