I was changing the consumer unit today and look how the previous person has earthed the main water and gas!
I will give them 10 out 10 for ingenuity:confused:
Here's how it looked after i had finished.
On a totally different job i was called out to i came across this fitted by a so called electrician.
The bottom of the rcd is feeding straight out to the RFC.
How he thought that a 63amp RCD on it's own would comply with regulations is beyond me.I had to removed the enclosure and fit a larger one so that i could fit a 32 amp mcb next to the RCD as it needed.
The guy even charged £330 just to fit that unit!
It saddens me that cowboys like this get away with it and tarnish qualified electricians in the process.:mad:
There are never regulations such as..."An earth bonding conductor must not be secured to a pipe with cable ties". The regulations are never that specific.
I gave you the regulation that I believe applies, in the section 'Proximity to non- electrical services'. It would not be possible for another trade to work on a non electrical service without damage to the means of securing the bonding cable. That contravenes 528.3.3.
(From the BRB...reg number may have changed but it'll still be there).
You all seem to be dissing my tie wrapping the bonding wires but how would you take the wire across and support it? I can still see no practical reason why i cannot do it as i have done.Just because someones NIC bloke says you can't doesn't make it law.If any of the other posts of inspectors is to go by they seem to make it up as they go along.
The regulations would be one reason, so in doing what you have done you have restricted the maintenance/repair to the installations of other trades.
My other critic is your tails are in free air passing in front of other services, I understand at some point it may be necessary to do this as it taps into the meter/henley joint but would expect to see some form of restraint given the larger distance you have, consider a plumber making alterations to that pipe behind, he's going to be knocking against the tails which unless you correct me otherwise would be acting directly on the the meter/henley terminals.
I've a question based on OP photo of completed work. The new CU is installed on ply. I recently had my registration visit from my chosen CPS and the guy who came wants the CU I installed to be practically air tight.
I had a garage install with 2 x 2.5mm T&E and 1 x 1.5mm T&E installed down wall in trunking to CU. I channeled the wall out to allow back entry into the CU. The gap between CU and block wall is about 5mm. The inspector told me that it was not good enough and that I should be filling the gap with intumescent foam to prevent air getting into the CU and help fuel a fire.
Now I stood there sort of bemused and wanting to really argue it but thought for a second and asked about IP ratings of CU and if the front of the board should be sealed as the gaps between the MCBs would also be a violation. He was quite adamant about it and was stating that it all changed with amd 3.
Now OP has installed a CU on a flammable material, I wonder what my guy would have to say about that???
If you can be arsed, I would be tempted to email your CPS with a general technical question regarding the 'sealing' of A3 CU's with intumescent materials.
When the replies comes back, stating there is no requirement other than maintaining IP ratings, you could then respond with your Assessment experience, and ask them to comment on that.
It should be noted no IP ratings are given for the rear of a dist board as it is assumed it will be fitted direct to a flat surface and not raised away from it.
:eek: Sneaky
Noted. It is amusing how this reg still gives rise to debate. I expect everyone seen Wylex's Wylex launch NMFS Intumescents to further enhance Consumer Unit Fire Safety - https://www.electrium.co.uk/news/wylex-launch-nmfs-intumescents-to-further-enhance-consumer-unit-fire-safety, which they state improves CU safety :rolleyes:
Personally I'd have tucked the Tails behind the pipe to the left of the new Board then it could be clipped to the wall and there is also what looks like a ring final floating too. Also I can't see why the bonds on the pipes aren't nearer/next to each other? Where's the MET?
Maybe another photo further back might reveal more.
I'm not a domestic electrician amd my work's not perfect but if i post something criticising previous work I'd make sure mine was spot on.
Blackpool,Lancashire.
United Kingdom
One way of earthing the pipes.....
Bob Geldoff1234,
Des 56,
TrueNAS JBOD Storage Server
