Ongoing storage heater problems - some help would be much appreciated. | Page 2 | on ElectriciansForums
Discuss Ongoing storage heater problems - some help would be much appreciated. in the UK Electrical Forum area at ElectriciansForums.net
jedisparks
Have an on going problem with a storage heater (Dimplex CXL24N). I've been out to look at it 3 times now and the occupier says that it still isn't working properly.
I was originally called out to it because it didn't work. The thermal reset had gone (not uncommon) and the thermostat did not look in good shape, So I ordered a new one and fitted it (2nd visit). During this call I had all the elements out to take a look and test resistance and IR. They all had similar resistance accross the elements.
Then I got called back becasue the heater wasn't getting hot enough and on attending I agreed and would have expected it to be a bit hotter than it was. So I wondered if one of the elements had gone. However on feeling the front of the heater It didn't feel like one area was cooler than the rest. Also, the resistance accross the whole heater was 17.8 ohms which I figure to be about right. 240/17.8 = 13.48Amps, 240 x 13.48 = 3.2KW. So, for a 3.4KW heater that seems about right...??
Anyway had another call today to say that it still isn't right and I don't really know where to go next. I'm doing this for a landlord, in one of his rentals. So far I've attended 3 times and paid for a new stat but can't really charge him if I haven't fixed anything. Here is a list of what I have checked, have I missed anything?:
1) Stat - replaced with a new one
2) thermal cutout - reset
3) Elements - removed, examined for damage, continuity and IR tests satifactory
4) Isolator wall switch - Replaced as I did find a high resistance accross the neutral terminals
5) Checked continuity of supply cables from consumer unit - checked out fine
6) Got rid of all the dust inside the heater
7) Asked if they dry clothes on the heater - Occupier says no, but sometimes puts their socks on the back, not covering the air vent (I'm a bit suspicious of this but it doesn't explain what's going on).
8) Is it the time clock - the clock is inaccessible. However there is another heater in the flat which is working fine.
9) Checked resistance accross the whole heater from the isolator switch (in the off position) got a reading of 17.8 ohms
10) Fuse protecting the circuit checked out fine
11) Continuity from the busbar to the outgoing terminals on the fuse holder tested fine.
Basically, I'm stumped. any ideas?
Thank you.
Might end up doing this. I will price it up for the landlord and let him choose between doing that and more visits from me and more replacement parts.
This job has been bloody annoying to say the least.
If thermal cut out had gone to begin with why ? They dont just have to restrict air by drying clothes on the heater , its enough to restrict airflow by putting a clothes airer round the heater.
The most common problem with storage heaters i find is user error.
Make sure they are closing the output at night or it will run out around 4 PM and they'll say it doesnt work, are there signs of condensation in the room - if there are they probably are drying clothes in there regularly.
Could I offer another test?
Why don't you run a circuit from a 32a overdue rent device in the peak rate board to the off peak board. Take out all circuits on the off peak apart from the one feeding this heater.
Switch the circuit on. Then you can test everything and wait to see how hot it gets.
To be honest when I've dealt with these its more after than not the div tenant not knowing how to use it and not even turning the input heat up.
also another stupid thing they do is leave the output flap up when the the heater is on over night? The heat just goes straight out of it.
Best thing is to ask the tenant to describe to you how exactly they are using it. Don't give them any prompts.
Bet its their fault.
There is a capilary stat a the back of the heater near to the cable entry , and its on a slidding plastic flap , this should be lowered usually when the feet are put on the heater, it could be that it has'nt been lowered and is picking up the higher temperature , this stat is to sense room temperature during charging
Quick Update: the problem turned out to be the thermostat that I replaced happened to be faulty. I had completely run out of ideas, tenant not happy, landlord not happy, me not happy. Was ready to throw in the towel, but thought I would change the stat again, NOW it works. Fancy that... faulty out of the box brand new stat. Crap replacement parts for storage heaters - beware.
Yes, but I had already tested that the faulty stat was working when I fitted it, like you, from the double pole switch. The heater was getting slightly warm but not as hot as might be expected from the setting of the input. So, I can only assume that it was just switching off at a lower temperature than it should have done.
Sounds feasible. Glad it's sorted. Nothing worse that an inconclusive fault.
Its great you found it we all get jobs like that sometime
Reply to Ongoing storage heater problems - some help would be much appreciated. in the UK Electrical Forum area at ElectriciansForums.net
From the front cover of the manual: Newlec Helpline: 0800 783 6909 https://www.manualslib.com/manual/3408290/Newlec-Nlsh050.html#manual I think...
Thanks all for the suggestions! Customer doesn't store anything else in the cupboard with the tank, not even towels or sheets. Heatrae stat is...
