Discuss Opening up holes for down lights in the UK Electrical Forum area at ElectriciansForums.net
1/ Cut a template of the correct size hole in a piece of plywood.
2/ Hold the plywood over the hole you want to enlarge.
3/ Place the hole saw in the plywood and apply a slow speed to mark and start the hole.
4/ Then either apply more pressure until you're through or remove plywood template and finish the hole cut.
5/ Don't forget to move the existing cables to one side and check also that you actually have the room to make the hole.
6/ Some existing holes sit close to joists, so you may need to offset the new hole.
That post above is just comical, what a mess about trying to hold plywood up whilst padsawing the hole out
Reply to Opening up holes for down lights in the UK Electrical Forum area at ElectriciansForums.net
