Opening up holes in joist | Page 3 | on ElectriciansForums
Discuss Opening up holes in joist in the UK Electrical Forum area at ElectriciansForums.net
pc1966
V.Nearly Esteemed
Dundee
A friend of mine is looking to have an electric shower fitted and has floorboards up already (mostly, long story). Anyway there is a run of 2.5mm T&E already following a sane route that the 10mm T&E for the shower could take, but the holes are just a bit bigger than 2.5mm and certainly not enough for both.
It seems like a bad idea to drill more holes in the beams, so I would prefer to open those holes out to around, say, 22-25mm to take both cables. Most auger or flat-blade drill bits assume no existing hole so the pilot can keep them centred, so I was wondering if anyone has good suggestions for doing opening such holes out in a sensibly controlled manner?
TL;DR drill options when existing hole is present in a wooden beam
Reply to Opening up holes in joist in the UK Electrical Forum area at ElectriciansForums.net
