Opinion on current fusebox | Page 3 | on ElectriciansForums
Discuss Opinion on current fusebox in the UK Electrical Forum area at ElectriciansForums.net
Chris1895
London
Hi,
Moved into a property of late that has the following fuse box. Got advice telling me that it's safe, but doesn't meet current regulations, as well as that it could go in the next year, or last another 15.
Want to get opinions on next steps. Ideally, I'd like to replace it with a consumer unit, but conscious that might be tricky. Any views on differing options would be much appreciated. House is ex-local ~1960s.
  • [ElectriciansForums.net] Opinion on current fusebox
No RCD protection essentially means if you for example stuck a fork in a socket, instead of getting belted you simply die.
Upgrade it to a new RCBO set up, you won't have to touch it again in your life time.
Changing the CU to one with rcd is not advisable with wiring that old.
There may be faults, borrowed neutrals etc that won’t cause a visible problem until rcds are introduced.
Testing has to be done beforehand.
If it can all be done together, then that is preferable.
Time to get the insulation tester out to check for low values of IR and shared neutrals then eh...?
So very different opinions - someone said I drop the ceiling 1.5cm via plaster and run the cables through there?? Another person said to create 2 different circuits, pushing the cables through and re-wire that way, with the kitchen being on it's own circuit.
As an FYI walls are rock solid, so not sure chasing will be possible without some serious leg work.
Reply to Opinion on current fusebox in the UK Electrical Forum area at ElectriciansForums.net
An example of the long term race to the bottom of quality of work in our industry, IMHO.
