Optimal panel will not reset | on ElectriciansForums
Discuss Optimal panel will not reset in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
albi
north east england
Hi every one
I have a optima XL6 panel but I think some one has changed the PCB from another optima panel and I don't seen to be able to reset the NVM back to factory and help whould be gratefully appreciated
[ElectriciansForums.net] Optimal panel will not reset
Just done a Google Images. Says its a Texecom Odyssey...
hi Spoon
i think you have mis read your google image its asking how to fit a texecom odyssey bell box to that panel
balls.... I need to go home...
Second guess.. On Ebay.
Looks [ElectriciansForums.net] Optimal panel will not reset
Texecom bell to the Honeywell panel
+ve supply A to D
OV D TO A
VE C TAMPER to T VE TAMPER RETURN
VE BELL B TO B VE SOUNDER TRIGGER
-VE STROBE S TO STROBE -
That's down to me posting incorrect info @buzzlightyear
What the OP's after is to "reset the NVM back to factory" but was thinking the alarm PCB was not a XL6.
spoon is the old optima XM.
power down
factory tests to remove wires from 9 and 19
put a link 9and 19 power up
the panel will power up with no alarm condition
with a cleared NVR the tamper and the indicators will remain steady
remove the links put back 9 and 19 and the way you go
power down
wrong.power down.connect PA 13 to set + 23. power up. power down, remove link. might need to do it twice.
Reply to Optimal panel will not reset in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Thanks. I do a lot more for the site than just change a few alarm batterys. EICRs, PAT, numerous little jobs. Never away from the place.
hi yes i agree its a final pir circuit with 30 seconds entry and exit programmed in no other detectors on route to rkp tried a different...
