R
Roger
Need some guidance from the wise old forum please
Have a issue with a rcd tripping,Thought I had issue with original marked downstairs ring so did continuity end to end at CU all ok after I did R2 cpc ,all ok whole house lights and everything,good values for cpc so that was ok .Did Cross connection l/cpc and n/l out and in, you know the figure of 8 to get the R1 and R2 readings.All the sockets in the whole house both floors seemed ok apart from 3 ! .1 socket in the UPSTAIRS bedroom and 2 sockets in the Downstairs front living room had high readings of 24.9/25 ohms everything else seemed ok with readings no higher than 1.10.For info front room had 4 socket the other 2 were fine.All sockets were wired as rings and had 2 cable entries no spurs.
Very strange so reconnected CU back up and then checked original marked upstairs ring,end to end ,cross connected and the 3 sockets with high readings seemed fine with acceptable readings.Out of interest checked other sockets that were ok with first tests and they all had voltage so could confirm that they were all feed from the so called downstairs ring.
Question why the high readings ? ,ring main crossed somewhere ?
For info they had a socket in the toliet,only a small room and a child could pee on it easily.I think every light switch needs replacing as they all feel very worn and gritty when switching.Old house again for info she did want the meter relocated moved down the into the hall about 4 foot ,Electricity board quoted £1500 and could not do it for 9 weeks.No more than 4 hours work tops.,
She's just getting the house back together she will be very annoyed if I have to pull floorboards up.
Any ideas ?
Any ideas ?
