Out door cable for lights | on ElectriciansForums
Discuss Out door cable for lights in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hounslow
Hey guys
Would like recommendations on what type of cable you guys would run for outdoor lights which are covered by a porch ceiling. ( if that makes sense )
The cable would be clipped direct.
Would you guys recommend pond wire which is water proof or SWA or even normal flex wire ??
normal flex is fine esp. if out of the weather. sunlight will slowly degrade white flex. black is better. if in doubt, use pond flex (or silicon flex) to be on the safe side.
PVC sheathed cable may have water resistant properties however, PVC is not waterproof. If submersed for a period of time water will penetrate the PVC.
think the word "weatherproof" would be a better description than "waterproof" in relation to pvc flex.
Reply to Out door cable for lights in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Thank you so much for your help with this light work perfect now thank you again much appreciated
Hello Brianmoooore, Thanks for yor reply - Sorry that I did not see your message until today - the Forum replies notification emails about your...
