Hi all,
Just joined this forum whilst doing research, so thought why not ask my question directly.
I am going to have a small split system aircon unit installed for my bedroom.
It will be a modern Mitsubishi unit with a starting current of only 3.5 Amps, nominal running current of 2.9 amps and absolute maximum running current of 7.3 Amps.
For convenience, I was intended to spur off a double socket in the bedroom straight through the wall and run 2.5mm T+E in plastic conduit down to where the outdoor unit will be.
(I know a dedicated supply would be preferable, but the Consumer Unit is the other side of the house)
I will install a 4 pole rotary isolator next to the aircon unit for maintenance isolation purposes.
Question: For this type of installation, do I need to install a Fused Connection Unit between the double socket and the rotary isolator?
Thanks in advance for any advice given.
