L
llcooldl
Hi All,
I'm installing outdoor lighting and electrical supply to a summer house at the bottom of a 100ft garden.
The overall load is going to be as follows:
10 low energy decking lights (up to 50 foot away from summer house / 40-70 foot from house), running from a 12V transformer.
6 Outdoor lights on the patio at the end of the garden (m.ains powered)
Standard lighting in a small shed (1 light socket) and in the summer house (2 light sockets)
And the summer house will contain a fridge freezer and stereo (two double sockets)
Will also run garden electrical equipment (lawn mower, strimmer etc.) from outdoor sockets (1 double).
I will be using SWA cable from the house to the end of the garden in the summer house.
Most probably fitting a garage consumer unit so that the lighting is off one side and the sockets off the other.
There will be a spur switched fuse at the house to be able to shut down the whole supply.
All the lighting will be on one light switch at the end of the garden (rather annoyingly as I can't work out an inexpensive way of doing it!).
All outdoor switches / sockets will be IP66 rated.
The CU in the main house has no capacity for a dedicated outdoor circuit and is RCD protected.
My concern is that this will be too much load for a spur from the main house (I planned to use a 30A junction box?
Should I extend the downstairs ring main instead of a spur (doubling the amount of SWA!) or does that make no difference?
What SWA should I use for the main run? Does it need to be more than 2.5mm? (I only ask as I have about 100m!)
All advice greatly appreciated!
Andy
P.S. If you are "qualified" to do the above work and live near Hockley in Essex please get in touch! Given my dad is a sparky I can't believe I'm having to pay someone to do the work! LOL
Andy
