outdoor lighting cable selection protective device | Page 2 | on ElectriciansForums
Discuss outdoor lighting cable selection protective device in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
What that spec clearly states is that it can only be used outside with additional protection, one example of which is protection from sunlight.
It does not state that it can be used outside on its own.
What is the BLUE flex used for. Is that designed for outdoor use for all weathers and varying temperatures?
It depends on the type of insulation and sheath it has.
There is blue PVC flex, blue HO5 flex and blue arctic flex on the market.
All three are being sold as 'arctic grade' but only one of them can actually stand up to external use.
Years ago it was acceptable to use blue arctic in the events industry, but it has not been allowed for a few years now due to there being so much blue flex around which is not suitable for outdoor use.
And if you do get proper arctic flex then you will find that, as the name suggests, it's main feature is flexibility at very low temperatures. It does not have the good mechanical strength of HO7-RNF which is the current standard.
there is also blue armoured.
i think it looks nicer than black swa lol, pretty colours lol
Reply to outdoor lighting cable selection protective device in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I've made the required tweaks on the junction box with a 4mm hole bottom, upturned wagos and reduced the exposed copper. I did originally install...
Yes, I realised the best thing would be to just fit a floodlight (LAP Weyburn Outdoor LED Floodlight Black 20W 2000lm - Screwfix -...
